CCV delete help - Ford Powerstroke Diesel Forum
Old 12-26-2012, 08:35 AM
CCV delete help
Alright I need to know how to do this CCV delete cause I am losing all my oil out of it. I disconnected it and turned it down and drove down the road and got back and I can see a pretty good amount of oil has ran out of it. How can I stop this? I know I am suppose to run a hose out the back under my cab but will that stop the oil from being lost? If anyone knows anything about this please help!
Old 12-26-2012, 08:56 AM
route the hose up and over the brake booster then down to the frame and back
Old 12-26-2012, 10:12 AM
To your question, no, it won't do anything about your oil loss. You'd have to recover that oil somehow, and not just slough it off on the street. But the first thing I would do is try to determine whether that's the cause of all the oil loss, or if you have some other cause at work.
Old 01-04-2013, 10:14 PM
If it is routed over the brake booster and you are losing that much oil, then I would say you have excessive blow by. It is not supposed to dump oil out of the CCV hose unless it is routed incorrectly.
