Exhaust Leak Help - Ford Powerstroke Diesel Forum
Old 10-30-2007, 05:45 PM
Send a message via AIM to rockarmymedic Send a message via Yahoo to rockarmymedic
Exhaust Leak Help
I just installed the AFE 4 in tubo back full exhaust system. Now I have a massive leak which sounds just like a broken exhaust manifold leak in a gas engine. I have checked the manifod, and replaced the gaskets on the manifold. Additionally I have repaced the Doughnut gaskets on the turbo exhaust intake pipes that run up the back of the engine. I have gone to a few exhaust shops and they have told me that I am hearing the exhaust in the much larger pipe but I dont believe them. Does anyone have any Ideas where or how to fine the leak.
1997 F-250HD 4X4 7.3L 285/75/R16, 456 locked Ft and Rr
Old 10-30-2007, 05:48 PM
Did you check the turbo clamp, sometime if you dont get the down pipe just right it will leak.
Old 10-30-2007, 05:51 PM
Can you see any soot around the pipes, or joints another thing you can do is run a stethoscope over all of your joints, and gaskets that will be very loud however. But these things do sound alot different with an exhaust on them.
Old 10-30-2007, 05:56 PM
I have excessive flatulance!!
Send a message via AIM to Diesel Nick
a boost gauge will tell you if u have a leak or not...
Old 10-30-2007, 05:59 PM
International Threat
not if it's post turbo!
Since it happened AFTER the exhaust install, I'd presume you didn't get the Downpipe clamp all the way on...
Old 10-30-2007, 06:00 PM
Maybe a soundclip will help us? Or a video? Or find someone locally to give you a hand that's been around for a while! Try the AZ threads!
Old 10-31-2007, 04:02 PM
Thank You
Thank you all for your help. I am going to try and reclamp the turbo clamp and also listen to the seams. I have not seen any soot from any of the joints or gaskets. Thank you all again.
