wAIT TO START LIGHT ALWAYS ON - Ford Powerstroke Diesel Forum
Old 12-14-2012, 12:40 PM
CAN SOMEBODY PLEASE TELL ME WHAT WOULD BE CAUSING THIS LIGHT TO CONSTANTLY STAY ON ALL THE TIME PLEASE HELP
Old 12-14-2012, 03:04 PM
(You don't need to shout....)
Could be an internal short in the glow plug relay, shorting the coil circuit to the contact circuit.
Try this - figure out which "big" terminal on the relay is the one that's always energized, and disconnect it from the relay. COVER that terminal on the end of the wire, since it's HOT, you don't want it touching a ground. Now turn the key to RUN, and see if the WTS light goes on and then goes off after 10 or so seconds like it's supposed to.
Old 12-14-2012, 04:11 PM
lol wasnt shouting just forgot caps lock was on and ok cool ill try that thanks a ton
