97 f250 no start after replacing banjo fuel line - Ford Powerstroke Diesel Forum
post #1 of 3 Old 12-03-2012, 11:50 AM Thread Starter
Hey guys im new here and ive got a question for you guys. I got a 97 f250 that had a leaky banjo fuel line. i have replaced the fuel line and fuel filter. After replacing that i cracked the lines and turned it over till i had fuel spraying out. I then reconnected the lines and still no start. ive tried starting it prolly 10 times. So my question is what do you guys think should be my next step? any advice is greatly appriciated.
bigal97 is offline
post #2 of 3 Old 12-03-2012, 12:32 PM
Patrick Feeley's Avatar
Quoted: 15 Post(s)
Welcome!
Wait-to-Start light coming on? Sometimes the fuel heater element can become dislodged during a filter change (element shorts out and blows underhood fuse #22 causing a no start). If the fuse is blown, disconnect the fuel heater (2nd wire down on drivers side of fuel bowl, funky looking spade connector), replace fuse. Cheers!
Patrick Feeley is offline
post #3 of 3 Old 12-03-2012, 12:40 PM Thread Starter
the wts light is not coming on i forgot to put that in there lol and ok let me go try that real quick
bigal97 is offline
