Weird cold idle - Ford Powerstroke Diesel Forum
post #1 of 4 Old 11-30-2012, 08:54 PM Thread Starter
Weird cold idle
I started having an issue with my idle when the truck is cold. It'll start just fine and idle just fine. I usually at least let the glow plugs go completely off before I touch the gas pedal. Well once I see the alternator gauge go up to normal range, and it's idling fine, it will start doing doing this weird fluctuation of about 100 rpms. At the same time the alternator gauge will start fluctuating too. The battery light does not come on. I installed a 215amp alternator a little bit ago. Other mods (back this summer): IDM mod and the 10k mod (c00nhunterjoe way). If the truck is really cold, once the glow plugs are off, I'll give it some gas and let it sit at like 1200 rpms for a few minutes to help it warm up more. Sometimes even while doing this I can hear a change in the sound of the engine and I can watch the alternator gauge fluctuate (the rpms don't fluctuate much when I'm hi-idling it). Hopefully my description makes sense. Any help will be appreciated. Thanks
Lee
warrior_84 is offline
post #2 of 4 Old 11-30-2012, 10:58 PM
jwatkins's Avatar
That is your glow plugs. The sound you are hearing is the relay pulling a lot of amps from the alternator. It's perfectly normal. You glow plugs will cycle on and off for a little bit to make sure all cylinders are firing.
B] 97 ford f-350 Powerstroke[/B]
d-60, 02' zf-6 tranny, 6637,FPR Shim, Custom Dual 5" Exhaust and 3" dp, TS six position, Devils Own water/meth, DIY Exhaust brake, Pro-tech headache rack with Peterson LEDs, home made front and rear bumper, DIY leveling kit, SD steering column pod, Isspro EGT and Boost, Home made OHC.
jwatkins is offline
post #3 of 4 Old 12-01-2012, 02:05 PM Thread Starter
Oh wow... It was that dumb of a question?! Thanks for the info haha. Sorry
post #4 of 4 Old 12-01-2012, 02:14 PM
kinnisoj's Avatar
Quoted: 2 Post(s)
Hey dont be sorry I learned from your question. Thats what is great about this site. Never know what your gonna learn.
,edge turbo timer
5" TB DIAMOND EYE EXH
ATLAS 40
TITLE IN HAND...
kinnisoj is offline
