Rear drum applying without pedal - Ford Powerstroke Diesel Forum
Old 11-15-2012, 05:24 AM
My passenger side rear brake is applying itself while I drive but only on cold mornings. On my way to school about 6:45 it's around freezing and every 50 yards there is a scratching noise and the one wheel slows down, it seems only to happen when I let off the throttle. By, about 2:30 the noise either stops of maybe does it quietly for a mile then stops. The tempature is about 65 to 70. The mechanic tore it apart and cleaned a lot of dirt and dust out of the drum, the first day after that it was better, but it's back to the same way. I live on a one mile dirt driveway and the truck is a '97 F-350. What could this be?
Thanks,
hwstem
Old 11-15-2012, 05:47 AM
replace the springs holding the shoes and check that the wheel cylinder is not seized up.
Old 11-15-2012, 06:04 AM
Do you use your emergency brake the night before this happens?
Old 11-15-2012, 07:00 AM
I don't use my emergency brake at night.
Old 11-15-2012, 07:03 AM
I'll have to take a look at them. Thank you!
Old 11-15-2012, 07:24 AM
I have the trouble with my passenger side rear wheel, my emergency brake doesn't release , and drags when I drive sometimes
Old 11-15-2012, 07:28 AM
Could it be a bad cable? We had one break on our 2000 F-350 Triton at work this summer.
Old 11-15-2012, 07:37 AM
I am also looking at this problem. 06' 350 rear passenger side. I beleive it to be a cable issue combined with the return spring. If I an turning or banking left it is very apparent. If I am going to the right te noise goes away. This leads me to think the cable is a big player and has slightly more tension from the frame while going left.
Sent from my iPhone using AutoGuide.com App
Old 11-15-2012, 07:41 AM
Doesn't the 06 have rear disc's?
Old 11-15-2012, 08:24 AM
De-rail in 3... 2... 1...
Thanks,
hwstem
Another suggestion, remove the drum and inspect the shoes for grease. At the top, midpoint, and bottom of the shoes should be a patch of anti-seize to make sure the shoes are sliding easily. Next, remove the cable from the parking apply arm and remove from the backing plate. At the other end of the cable disconnect the cable at the equalizer bar too. On one end remove the dust shield (pull it forward on the exposed cable) spray in a little WD-40 and work the cable in and out of the housing for a minute. Repeat till you can feel it acting smoother. Go to the other end and repeat there. Reattach everything and test operation.
Even with disc rears the parking system is still drum based inside the center of the rotor.
Tags
rear drum applying squeak
