engine cutting out while driving - Ford Powerstroke Diesel Forum
post #1 of 12 Old 10-25-2007, 06:12 PM Thread Starter
so this has happened twicw now, i forgot about the first time until it happend again this morning.
what happens is in the morning after i warm up the truck for about 3-5 min and start driving at a consistant speed it will very briefly cut out radomly unitl i get where im going. then its fine . like i said this has only happend twice so i dont what to think of it....any ideas?
tracyb is offline
post #2 of 12 Old 10-25-2007, 06:27 PM
sldghamr's Avatar
have you checked codes from your computer??
sounds like a possible CPS problem.
if you see a light at the end of the tunnel, it's probably just a photon torpedo
sldghamr is offline
post #3 of 12 Old 10-25-2007, 07:06 PM Thread Starter
i haven't checked any codes but it doesn't have a check engine light on.
should i still try to check?
tracyb is offline
post #4 of 12 Old 10-25-2007, 08:05 PM
Electrical Ogre
alberta 7.3's Avatar
Quoted: 126 Post(s)
When the CPS started to fail on my 96, it didn't throw on the check engine light, just some random stalling. Your best bet is to check for codes
Bill
1996 F250 SC/SB 4X4 XLT
1997 F250 RC/SB 2WD project
2008 F350 CC/LB 4X4 DRW Lariat, 3" cow catcher mod
2008 Ranger SC FX4
Originally Posted by weareweird69 View Post
If your posting pictures bill, everyone dim their screens, that CAT YELLOW is bright
Originally Posted by Fordman247365 View Post
Is there anything you DONT take apart and **** with?
Originally Posted by JJFLASH View Post
I still say that those Dodge mirrors have as much business on a OBS Ford as yoga pants have on a fat chick...my .02
alberta 7.3 is offline
post #5 of 12 Old 10-25-2007, 08:31 PM
Albie30's Avatar
Send a message via AIM to Albie30 Send a message via Yahoo to Albie30
Do you have a chip if so check to make the connection is solid going to the cpu
2000 F250 cc 4x4 4" lift BFG 315's,,dp tuner Auto Meter gauges, Hybrid 235cc injectors,TN BB turbo,water meth injection,Ragin intake,ITP boost fooler Banks intercooler,big head wastegate,power elbow,torque converter,6.0 tranny cooler,High flow intakes AIH delete air ride air bags,gibson 4" exhaust,zoodad mod, remote start, Pioneer dvd/ navigation Sirrus radio,sun coast tranny ,Bts valve body,H11 s,Engine rebuild .030 over,Fluid Dampner,203 thermostat
425hp 775 Tq
13.9 @ 95 mph
Albie30 is offline
post #6 of 12 Old 11-03-2007, 04:38 AM
Powerstroke Junkie
NCHornet's Avatar
Sounds like either a chip coming loose or a CPS going bad. It won't always throw a code if it is just a brief hiccup. I would swap CPS's, you should have a spare anyway and they are cheap now. Good Luck.
NCH
Proud Father of USAF Airman
2000 F350 DRW,CC,LB, 4X4, Western Hauler Pkg.
Ford AIS/ BTM, FTVB
My CCV MOD, Coolant filter
06 Grill, 05 lights,6.0 trans cooler
Cyro/Hawks, JVC Touchscreen HU, JL C5's, Infinity 800watt amp,
DP tunes, 60 tow/80 e/120 race, on a SCT2 tuner
P3 controller, Brite Box Turbo Lifesaver
KMC Wheels x 4
Friends Don't Let Friends Drive Trucks With Generic Tunes
NCHornet is offline
post #7 of 12 Old 11-03-2007, 05:44 AM
Same happened to me changed the cam position sensor problem went away. Used to happen a good bit while the wipers were on.
MIKIEPOPS is offline
post #8 of 12 Old 11-03-2007, 07:17 AM
1999 F250 7.3L, engine would just skip while driving above ~35mph. If stopped it would cut off. Read the posts here on powerstroke.org and found that the cam position sensor may be bad. Got one at the ford dealership for ~$30.00, replaced it today and so far no skipping or cutting off.
Thanks for saving me some $$$$$$$$!!!!!
Autie22686
autie22686 is offline
post #9 of 12 Old 11-03-2007, 08:50 AM Thread Starter
i got mine fixed too, called around and was quoted prices from 150-200 then napa said it would be 40 so i bought it put it in and no more problem.
thanks
tracyb is offline
post #10 of 12 Old 11-03-2007, 03:03 PM
Great I have replaced mine twice would usually skip around 30-60 mph when the wipers were on and sometimes cutoff and restarted right away. One time it cut out and would not restart until the engine had cooled , next day replaced CPS with a aftermarket one worked then started again picked another sensor this time from a Ford dealer no more problems.
