96 powerstroke problems.
ok my 1996 f250 7.3 has 231k was my dads old work truck and i bought it..
so its 60s out and wen you go start it wont start u spray it rummmmm runs but its a PIG!!. 1 more thing with the damn brake lights you smash on them nothing u hit the brake box slide and thay come on???.
Brake box slide? Are you asking about the slider on the trailer brake controller? |
Is your 3rd brake light bulb still good?
i will check that. also wen ur starting it LOTS OF WHITE SMOKE!!!?
If it's cold out yep there can be a lot of white smoke. Another indication that the GPRS or the Glow Plugs aren't up to snuff.
3rd brake light works.
POWER JOKE HELP. ok my truck was runing fine then it started loping it was on e flip to the front tank and the it died so then it would not start tryed every thing then tryed and chang the filter and it strip phucking plastic whats ur IMO.
have white smoke but wen u pull the fuel filter there's no fuel?
No fuel in the bowl or just real low? Looking like a fuel pump died on you. With the filter off have someone crank the engine while you watch to see fuel movement.
