HELP PLEASE!! stranded here... Blowing the 30 amp fuse to starter, can someone please tell me where exactly is the heater disconnect on the bowl for a 96 7.3l f250? There is a lot of stuff plugged in there...
Thanks, desperately yours CR Wright Last edited by cr-wrig9933; 11-04-2012 at 08:36 AM. Reason: Stranded!!! |
It's on the drivers side and IIRC it is just a push on terminal
Well there are 2 posts, one larger and one smaller right below. They're both right in line with the heater...
Look for the one with the red/green wire. But the fuse that energizes the fuel heater energizes the PCM, not the starter. If you're not even cranking, you've got something else going on.
Thank you for for the details, it was the very bottom post on the drivers side of the bowl. I also pulled the stinger out of the bowl just to be safe. Runs fine now.
