97 psd oil in coolant - Ford Powerstroke Diesel Forum
Old 10-20-2012, 11:52 AM
[/U]problem with oil in my coolant. I have a 97 F-350 and have oil in the coolant but no coolant in oil or filter. I need to know if this sohow do I checkunds like a bad oil cooler o
r some thing else ?
Old 10-21-2012, 06:42 AM
I think I get the jist of your post (maybe ... complete sentences help others understand). First, make sure the "oil" is not fuel, which would indicate possible cracked injector cups. As far the possibility of an oil cooler leak, I would just get the o-rings and gaskets and reseal it. I would also do a good flush on the cooling system. Cheers!
Old 10-21-2012, 01:12 PM
Sorry about the word jumble ! Don't know what happened it was a clean sentence when I typed it ? Thanks for the info . Yes it is oil and not fuel , I had to fill the crank case then found the problem !
Old 10-21-2012, 01:16 PM
By the way what should I use to flush the system ? I heard dish soap solution!
Old 10-22-2012, 08:44 AM
I would go with something like Fleetguard Restore or Restore Plus (that's just me). I know some guys just use Cascade. Cheers!
Old 10-22-2012, 10:42 AM
Ok l'll have to look for that thanks !
