hey guys need help electrical issue
928 views 4 replies 3 participants last post by  agonzo90
#1 ·
i have a 94.5 350 cclb and i just installed cab lights on the roof but now i have no dash lights or radio i changed the fuse for the cluster lights 3 times just in case and iam still not getting power to it is there another fuse under the hood i can check and does anyone have the glossary for the underhood fuse box cause i dont have the owners manual thats shows me what is what any suggestions would be great:tard::dunno:
#4 ·
Where did you tap into power for your cab lights? Sounds like you might have grabbed an illumination or dimmer wire seeing as how your radio and gauge cluster lights quit working. Do the cab lights light up? Does the gauge cluster fuse continue to blow when you replace it or is that fuse not getting 12v?
