95 PSD Not Starting
So this started happening about 2 weeks ago, on mornings that are cooler (50 degrees or cooler) when my truck has been sitting all night it won't start. It tries but it usually takes me 3-5 times of letting the glow plugs warm up, trying to start, stop then over again before it will actually start. When trying to start it there is a TON of white smoke pouring out of the exhaust and a little from under the hood. Once it starts it runs fine.
Anyone know what this could be? And have any idea how much it will be to fix? |
Do you have a volt meter? Have someone in the drivers seat. With the meter find the hot side of the Glow Plug Relay (big lug not one of the small lugs). Now place the the positive probe on the cold side of the GPR and have the person in the car cycle the key to the run position. Does the cold side of the GPR now have full battery voltage?
More than likely your glow plug relay is bad.
^ I suspect it also. Yes the first start of the morning is the hardest on the engine. All the white smoke leads me to believe that the GPR isn't working and the cylinder isn't hot enough to burn off all the fuel. Mine does this every winter.
When you say "3-5 times...", do you mean you let the GPs fully cycle (75 seconds or so at 50F), turn the key back and turn it to RUN again, 3-5 TIMES? That's 5-7 full minutes of GP time! If that's what it takes to start the truck, then indeed, you've got a GP issue.
Cycling the glow plugs is useless, they will stay on as long as needed. They stay on after the WTS light is off. Up to two minutes IIRC. Best practice is to leave the key on for longer, rather than turning the key off and on repeatedly. In very cold weather I leave the key on for 30 seconds then start. Works like a charm.
Ok, thanks for all the advice. I figured it would be something with the glow plugs, I will let them sit a little longer tomorrow and see if it fires up on the first try.
So what needs to be replaced you think? Any idea on the cost? I still haven't done the volt meter test yet.. |
Is this the correct replacement part if it is the GPR?
OEM Style Ford Diesel Glow Plug Relay Solenoid 6.9L & 7.3L Powerstroke, Turbo, 1985-2003 E-Series Econoline E250 E350 Van, F-Series Pickups 1994 95 96 97 98 99 00-2003 F250 F350 F450 F550 F650 F750, 2001-2003 Excursion, with International IHC T444E - |
I suggest replacing it with a stancor relay.
Welcome to guzzle's Stancor GPR replacement Mod Web Page 586 105111 White-Rodgers | Mouser |
