Battery Light - Ford Powerstroke Diesel Forum
post #1 of 22 Old 08-07-2012, 02:54 PM Thread Starter
Battery Light
I started my truck today and the battery light came on. Let it run 15 minutes then shut it off and restarted it about 5 times without any problems. What all should I be looking for?
tucker0104 is offline
post #2 of 22 Old 08-07-2012, 03:09 PM
nightofstars's Avatar
F250 '95 Powerstroke Battery Light Stays On
I have the same problem & 2nd this question needing to be answered, mine has almost alway gone on for no apparent reason, AND the ABS light although there's break fluid, etc.
Any info is good info on these matters.
nightofstars is offline
post #3 of 22 Old 08-07-2012, 03:57 PM Thread Starter
I am fine if it is just the battery light for no reason. I just don't want to be driving down the road and all of a sudden I break down.
post #4 of 22 Old 08-07-2012, 04:07 PM Thread Starter
It seems like the batteries are staying charged which means the alternator is working. Batteries are only about 6 months old. Could grounding straps cause a battery light?
post #5 of 22 Old 08-08-2012, 02:50 PM
BANNED by Kris
BigFuel's Avatar
Quoted: 50 Post(s)
Time for an Alt. When the Batt. light is on try tapping the Alt. housing. Might be a bad ground in/on the ALt. Food for thought:
Matt
-'97 Mini Monster
-Bean's: 160/100 (FF Injectors), 2/ 6-POS chips (TW & Beans tunes), Overboost controller, E-Fuel
-BANKs: downpipe, full exhaust, gauges, intercooler
-Irate: T-4 kit, IC pipes, 3" Irate Plenums, BASB Turbo
-Stage II trans.
-Mag-Hytec trans. and pumpkin covers
-6637, CCV, IDM, 6.0 Fan, 49-Federal PCM swap, MAP line Mod
-370 Amp alt., 40k trans cooler, ADRENALINE PUMP
-twin on-board air w/ 10 gal. tank
-'15 F350 6.7L DRW 4x4
BigFuel is offline
post #6 of 22 Old 08-08-2012, 04:00 PM Thread Starter
But there seems to be power. No way the alternator is bad but the batteries are staying at 14v when running.
post #7 of 22 Old 08-08-2012, 04:07 PM
BANNED by Kris
BigFuel's Avatar
Quoted: 50 Post(s)
Tap on the housing to see if it's a bad ground issue in the alternator. Otherwise inspect the LG/R wire from the alternator back to the light.
Matt
-'97 Mini Monster
-Stage II trans.
BigFuel is offline
post #8 of 22 Old 08-09-2012, 04:30 AM Thread Starter
I will check it today. Thanks for the help. Where can the wire be found on the alternator?
post #9 of 22 Old 08-09-2012, 04:32 AM
Send a message via Skype™ to bwmtnbiker
My cousins truck did this, pulled the alt off and took it to get tested. Tested bad and we replaced it. The light went away after that.
-Brian
2003 F-250 6.0L - Lariat King Ranch
-300k+ miles and still strong
Current Mods
-6.5" Pro-Comp lift
-Edge CTS
-SCT X3 (Tuned by Vivian
-4" Turbo Back Silverline Exhaust, 5"tip
-Blue Spring Mod
-Sinister Coolant Filter
-Oil Cooler
-Sinister EGR Delete
-OEM Cab Lights
Wants/Soon
-ARP Studs
-MTW Stage 1 or Hybrid
-6.4 Banjo Bolts?
bwmtnbiker is offline
post #10 of 22 Old 08-09-2012, 04:49 AM Thread Starter
Any recommendations on new alternator brands?
