95 7.3 turbo fuel problem - Ford Powerstroke Diesel Forum
Old 10-12-2007, 05:39 AM
My psd will shut down and then start again when running. I feels like a vapor lock or fuel shortage. This started the same day a had shop replace the AC compressor and dryer. Ofcourse they say it's nothing they did.
I have replaced the fuel filter housing assembly, the injector pump, the fuel pump and am running injector cleaner, but nothing has helped.
Any help would be greatly appreciated.
Old 10-12-2007, 01:55 PM
Any codes ?
And how is your MPG ?
Old 10-12-2007, 02:09 PM
ADMIN AND TECH
sounds to me like you need to do some diagnosis before replacing parts or its gonna get expensive quick , doesnt sound like a fuel problem or oil pressure problem to me , you need to get the codes pulled and let me know what code are in it and lets go from there
Old 10-13-2007, 07:06 PM
Electrical Ogre
Almost sounds like the cam sensor starting to go out, but as scuffy said, try pulling some trouble codes before shelling out hard earned dough. My truck did the same thing (stumble and recover/occasional stall) and set a P0344 (cam pos sensor intermittent)
Old 10-18-2007, 05:14 AM
Also sounds like a cam sensor to me. Mine did the same thing before the sensor went out.
