cutting out after startup randomly.. and a lack of power on the bottom end - Ford Powerstroke Diesel Forum
post #1 of 18 Old 07-09-2012, 09:22 PM Thread Starter
ok so on a random basis my truck will just cut out almost as if u turned it on and off
quickly.. sometimes it recovers and others it has to be restarted..
its only been at warm start up so far and happens rite after..
also my truck seems to be a dog off the line.. and feels generly lacking in the power department..
checked alot so far but running out of ideas..
fuel related? a short? bad injector?
idk but i tow a 26ft toyhauler.. 7100 dry and im in second gear on the local back road hill..
and my egts are are at 1200..
what do you guys think
foxfamilycustomz95f350dsl is offline
post #2 of 18 Old 07-10-2012, 11:04 AM
BANNED by Kris
BigFuel's Avatar
Quoted: 40 Post(s)
Yikes, 1200* in 2nd!. What is your running fuel pressure, HPOP pressure, and check your idle switch on the go pedal. are you running LED brake lights?
Matt
'97
-Bean's: 160/100 (FF Injectors), 2/ 6-POS chips (TW & Beans tunes), Overboost controller, E-Fuel
-BANKs: downpipe, full exhaust, gauges, intercooler
-Irate: T-4 kit, IC pipes, 3" Irate Plenums, BASB Turbo
-Stage II trans.
-Mag-Hytec trans. and pumpkin covers
-6637, CCV, IDM, 6.0 Fan, 49-Federal PCM swap, MAP line Mod
-370 Amp alt., 40k trans cooler, ADRENALINE PUMP
-twin on-board air w/ 10 gal. tank
-Oh, and a 2015 F350 6.7L DRW 4x4
BigFuel is offline
post #3 of 18 Old 07-10-2012, 11:08 AM Thread Starter
fuel pressure is verry erratic.. 30 psi up to over 90..
how do u check hpop pressure? also how do you check idle switch and how would that contribute
to my issue?
post #4 of 18 Old 07-10-2012, 11:11 AM Thread Starter
we talked before about my high egts and im thinking its all linked to something else..
any hill even empty ill hit over 1000deg
post #5 of 18 Old 07-10-2012, 11:23 AM
BANNED by Kris
BigFuel's Avatar
Quoted: 40 Post(s)
1/4" NTP soft line rated to at least 3kPSI and a gauge mounted to it for the same pressure. 4kPSI setup is safer but not necessary in stock trim engine. Run into one of the unused oil ports in the heads (careful not to damage the o-rings).
Fuel pressure gauge is bouncing because you are not using a fluid filled gauge and even then it'll still bounce a bit. Our fuel pumps step the fuel (causing it to pulse on the gauge) fuel to build pressure.
The idle switch on the pedal is a simple on/off switch and I am wondering if it is fighting the PPS for control of the engine. Test with a simple meter on Ohm setting and the two pins. Should make a simple clean 0.1 ohms and OFL (or infinite depending on the model meter). If it sticks or give wavering readings then it's bad and fighting the PPS.
Matt
'97
-Stage II trans.
BigFuel is offline
post #6 of 18 Old 07-10-2012, 11:25 AM
BANNED by Kris
BigFuel's Avatar
Quoted: 40 Post(s)
Remember you now. I was pushing a boost leak. Sorry, I guess this issue was fixed...
Matt
'97
-Stage II trans.
BigFuel is offline
post #7 of 18 Old 07-10-2012, 11:49 AM Thread Starter
ok.. im pretty sure any boost leaks i had are fixed...
ill check the idle switch here in a bit when im off work..
does a hpop get weak and not just quit? if its weak it would cause a lean system
wich would cause a lack of power and higher egts rite?
i herd that extreme fp bounceing could be a bad injector..?
my truck runs great other than the issue im having.. and on cold starts it does lope pretty
good for about 20 to 30sec..
thats a sighn of a bad injecter rite? shouldnt it be fairly smooth all the time?
post #8 of 18 Old 07-10-2012, 12:04 PM
BANNED by Kris
BigFuel's Avatar
Quoted: 40 Post(s)
On the cold start does it smoke? What color? A weak oiling system can cause cold lope also. Oil's cold and thick and needs to thin out. Yes the HPOP will more likely weaken over time then brake and fail. Think of the HPOP as a small two piston two stroke engine that is mechanically driven off the front of the motor. As it wears the pistons get sloppy in their holes and pressurize less oil per volume. A weak HPOP pressure can also be a weak/worn/stuck IPR. Can only check this with a scanner that reads live data. Needs to see a duty cycle of less the 50-55%
Matt
'97
-Stage II trans.
BigFuel is offline
post #9 of 18 Old 07-10-2012, 12:15 PM Thread Starter
smokes typical white smoke in the mornings till warm.. ive had 5 or so powwerstrokes.. and every obs i had smoked like that when cold
post #10 of 18 Old 07-10-2012, 12:19 PM
BANNED by Kris
BigFuel's Avatar
Quoted: 40 Post(s)
Straight white or blue-ish tinge? Tomorrow morning start the truck and smell the exhaust. Is it sweet? There is a difference.
Matt
'97
-Stage II trans.
BigFuel is offline
