Water in fuel light - Ford Powerstroke Diesel Forum
post #1 of 2 Old 06-29-2012, 07:00 PM Thread Starter
Water in fuel light
I've had this coming in and out. Mostly comes in and stays in. How do I drain the water out of the fuel line or tank?
tucker0104 is offline
post #2 of 2 Old 06-29-2012, 07:04 PM
Gaius's Avatar
Quoted: 40 Post(s)
It means there's water at the bottom of your fuel bowl. On the front passenger side of your fuel bowl is a drain (yellow tab). Turn the tab 90 degrees to the passenger and some fuel will drain down under your truck. If you want to catch the fuel add a piece of tubeing to the line. It's up under the passenger head above the axle.
05 F350 Crewcab
98 Jeep TJ - wheeler
Gaius is offline
