1995 fuel sending unit rebuild kit?? - Ford Powerstroke Diesel Forum
post #1 of 16 Old 06-25-2012, 09:22 AM Thread Starter
mikenj's Avatar
The brake line behind the tank got a leak so while dropping the fuel tank, both lines broke off the sending unit because they were rusted so bad. Ford wants like $400 for a new sending unit! I see autozone sells a rebuild kit, anyone use these? How does it work??
mikenj is offline
post #2 of 16 Old 06-25-2012, 09:59 AM
BANNED by Kris
BigFuel's Avatar
Quoted: 43 Post(s)
My Ford listing has 6 different sending units. Only one is more then $400, Unfrotunatly they all go by the same part number. I think the only thing different is the float arm and pick-up length depending on which of the 6 tanks you have. The common 19 gal steel midship is $320
Matt
'97
-Bean's: 160/100 (FF Injectors), 2/ 6-POS chips (TW & Beans tunes), Overboost controller, E-Fuel
-BANKs: downpipe, full exhaust, gauges, intercooler
-Irate: T-4 kit, IC pipes, 3" Irate Plenums, BASB Turbo
-Stage II trans.
-Mag-Hytec trans. and pumpkin covers
-6637, CCV, IDM, 6.0 Fan, 49-Federal PCM swap, MAP line Mod
-370 Amp alt., 40k trans cooler, ADRENALINE PUMP
-twin on-board air w/ 10 gal. tank
-Oh, and a 2015 F350 6.7L DRW 4x4
BigFuel is offline
post #3 of 16 Old 06-26-2012, 07:23 AM Thread Starter
mikenj's Avatar
Same p/n for 6 different units?? I'd still rather not spend $320 if I don't have too. I'm going to take a pic of what i'm dealing with. Thanks, Mike
mikenj is offline
post #4 of 16 Old 07-16-2012, 09:44 AM Thread Starter
mikenj's Avatar
OK, been ordering lots of parts to fix this truck myself but I still need to address this sender unit. Any idea where to get one?? LMC has one for $429.95!!!! I'll sell it for parts before I spend that kind of money.
mikenj is offline
post #5 of 16 Old 07-16-2012, 09:51 AM Thread Starter
mikenj's Avatar
Here are some pics of what i'm dealing with........
ID:	40342   Click image for larger version
mikenj is offline
post #6 of 16 Old 07-18-2012, 09:06 AM
95redrifle's Avatar
Quoted: 3 Post(s)
I remember when i was looking for a sending unit autozone sold a tank and sending unit for like 300 or so? I ended buying the ford sending unit though
tony
1997 F250 4.10's
D60 swap/mag-hytec rear diff. cover
ts 6 pos./Autometers
melling LPOP/T-500 HPOP
D66 w/1.0 housing and WW2
160/80 rosewoods/bellowed up-pipes
08 king ranch seats/center console
south bend clutch
95redrifle is offline
post #7 of 16 Old 07-18-2012, 09:23 AM
powerstroke2501997's Avatar
not trying to take over your post, but does anyone know how to fix an old sending unit, because my fuel tank is full and reading 1/4
Tony
1997 F-250
ts-custom chip, intake, 5sp, 4-5" exhaust
powerstroke2501997 is offline
post #8 of 16 Old 07-27-2012, 01:41 PM Thread Starter
mikenj's Avatar
Did a search and found a Co. in OH that rebuilds them. I just sent it out on the 26th so we'll see. Was quoted $139 which is ALOT less than Ford wants!!!
mikenj is offline
post #9 of 16 Old 07-27-2012, 06:21 PM
let me know how that goes and if it works if it does please pm me the results. address phone numbers n such thanks
Tony
1997 F-250
post #10 of 16 Old 07-27-2012, 07:09 PM
Fuel Pump
Anyone know how fast you should expect the fuel filter bowl to fill up when cranking the engine. I can't get my truck to start and thought it might be the fuel pump. Fuel flows in but not incredibly fast.
Chuck Kull is offline
