Uneven Tire Wear - Ford Powerstroke Diesel Forum
post #1 of 11 Old 06-25-2012, 05:58 AM Thread Starter
TexasAggie09's Avatar
Uneven Tire Wear
After my last tire rotation (35" BFG Mud Terrains), I really started to notice a "wah-wah-wah-wah" sound coming from the front passenger tire, formerly the rear drivers side. It increases with speed, causes a bad vibration and is REALLY loud, especially outside the vehicle. Looking at it shows a very unusual wear pattern. On the inside of the tire (closest to frame), EVERY OTHER lug is worn down substantially farther than the one next to it. What would cause such an usual wear pattern that not every lug would be worn the whole way around? I can't figure this out but it's driving me insane!
Thanks and Gig 'Em!
White 1995 F350 CC LB 4x4 7.3 SRW
Bought 8/27/09 with 183k miles
4 Position Chip, 35" BFG Mud Terrains, Bilstein 5125 Shocks, DIY Intake 6637, No cat/muffler, Carr Side Steps, Ranch Hand Front Bumper, Headache Rack, Rear Bumper
Fightin' Texas Aggie Class of 2009
TexasAggie09 is offline
post #2 of 11 Old 06-25-2012, 06:24 AM
atvrider93's Avatar
Quoted: 8 Post(s)
Check ball joints
Sent from my DROID BIONIC against my will
1996 F350 4x4 CCLB-- I'll miss her
1996 F350 4X4 RCLB zf5 213K
6637
OBA w/horn
DE 5"
PHP tunes
Mud Country 315/75/16
2008 Wr250X
Originally Posted by belz View Post
There u go Tom. John may not be sexy, but he can tutor you, lol.
atvrider93 is offline
post #3 of 11 Old 06-25-2012, 06:40 AM Thread Starter
Ball joints on the passenger side are good. They're bad on the drivers side but this tire hasn't been on the drivers side yet.
Thanks and Gig 'Em!
post #4 of 11 Old 06-25-2012, 09:29 AM
BANNED by Kris
BigFuel's Avatar
Quoted: 57 Post(s)
Bad shock combined with an out of spec tire balance. The slight out of balance can cause cupping as the tire loads and unloads down the road. Most tire shops balance the tire to 65 MPH. If your don't normally drive at this speed have the tire shop tune weights to your normal speed.
Matt
-'97 Mini Monster
-Bean's: 160/100 (FF Injectors), 2/ 6-POS chips (TW & Beans tunes), Overboost controller, E-Fuel
-BANKs: downpipe, full exhaust, gauges, intercooler
-Irate: T-4 kit, IC pipes, 3" Irate Plenums, BASB Turbo
-Stage II trans.
-Mag-Hytec trans. and pumpkin covers
-6637, CCV, IDM, 6.0 Fan, 49-Federal PCM swap, MAP line Mod
-370 Amp alt., 40k trans cooler, ADRENALINE PUMP
-twin on-board air w/ 10 gal. tank
-'15 F350 6.7L DRW 4x4
BigFuel is offline
post #5 of 11 Old 06-25-2012, 09:34 AM
BANNED by Kris
BigFuel's Avatar
Quoted: 57 Post(s)
Once tire wear starts it doesn't stop even after the corrections been made. Also check the rear suspension as cupping can start in the rear with a sagging/worn suspension and then exasperated when the tire was put on the front and asked to turn.
Matt
-'97 Mini Monster
-Stage II trans.
BigFuel is offline
post #6 of 11 Old 06-25-2012, 02:05 PM
southend's Avatar
I recently had A tire do what you are explaining, inspected the tire and found a slight bump and cup in one area. Busted belt, had it swapped for free because it wasnt very old.
Sent from my SCH-I500
Unfortunately had to Sell my ......2004 KR CC SWB FX4 - Edge insight cts, blue spring upgrade, updated HFCM drain plug, XDP coolant filter, CAT EC-1 rated coolant, Custom Diesel EGR delete, CAT delete, Rotella T6
SEE MY OIL COOLER REPLACEMENT AND EGR DELETE -
southend is offline
post #7 of 11 Old 06-25-2012, 05:09 PM
zROCK's Avatar
may have answered your own question. you could be compensating on the steering and actually wearing out the opposite side.
have similar problem but my outside edge is wearing
zROCK is offline
post #8 of 11 Old 06-29-2012, 04:08 AM
Bad shocks could do it.. or not rotating your tires every 3,000 miles. These big trucks need their big mud-tires rotated every 3k miles or so. Bad alignment and balance could do it too.
85_305 is offline
post #9 of 11 Old 06-30-2012, 09:48 PM Thread Starter
Thanks for the replies yall. I rotated that tire to the rear drivers side so it spins the other way and for the time being everything is smooth. A temporary band aid, I know, but I can't afford to buy new tires when these are under 2 years old and all my suspension components (shocks, ball joints, bearings, tie rods, u-joints) are also under 2 years old. Just need to last me another year or two and I'll buy another truck then can totally tear down this front axle and fix it right.
Thanks and Gig 'Em!
post #10 of 11 Old 07-01-2012, 06:16 AM
Like I said. Big mud tires need to be rotated every single oil change.
85_305 is offline
