new to me 7.3 psd overheating
So i picked up 95 f350 long bed crew cab ps today! but on the ride home it was overheating popped the hood and heard hissing from the res cap so replaced that and it got much better no more going into the red buuuuuuut im still getting like 3/4 of the way up. the level of the coolant is fine after i added 5 gallons. seems like tstat is working.
is it normal for the upper rad hose to be empty when it cools down? it has pressure after driving it for awhile but once it cools down its bone dry. im no expert but air in the system is no good right? the needle goes up to about the end of the word normal on the gauge is that normal? thanks for any replies! |
Sent from my SCH-I500 |
Is it normal for the upper hose to be empty when the truck is cold though? I was thinking it could just be air in the system
Sent from my Autoguide iPad app |
I think that's what happened because I did add the 5 gal of coolant and I didn't turn the heater on because I forgot because I was on the side of the fwy. How long should it take at idle to get hot enough to open the tstat? Is been idling for about 20 min and it didn't move any significant amount
Sent from my iPad |
Can I drive around with the cap loose? Maybe like that I'll reach temp
Make sure to remove the water from the system and run the correct stuff... these motors need special coolan or the cylinders will become porous.
