Low beam flicker!!!
This is driving me nuts. When im driving with my low beams on they will shut off for 5-10 seconds or more at a time. My markers lights stay on, my guage dont dim either. I can run blinkers, wipers at same time and it doesnt turn them off. It seems like vibrations cause it but the other day i pulled it into my shop turn them on and jiggled the wire to the housings, nothing. I then moved the grounds on the front panels near the headlights and still nothing. I dont think its a loose wire but maybe it is. Possibly the blubs or connectors?
We had this problem on a 98 crown vic, turned out to be the multifunction switch (turn signal/wiper/bright stalk)
I think the multifunction switch is what's causing my LH low beam to randomly cut in and out. New headlight switch and connector with pigtail.
Really? The headlight switch isnt even on the stalk its a pull switch.
I do remember one night it was doing it and i ended up turning the knob some and it stayed on all the way home. Maybe something to do with the knob? Contact points?
Same problem in my 99 though it was just one side. Turned out to be bad connectors. Bought a set of heavy duty/ high temp ones for about $15 and replaced them both. Might be worth a try first unless both are flickering at the same time. Then it sounds like the main switch on the dash.
Wouldnt you think tho that if it was the switch the high beams would flicker too?
On the crown vic, it didn't happen with the high beams.
Boy im torn, change out the bulb housings and bulbs first or the multifunction switch? I got a hot date sat night and i cant be driving around with a few drinks ine andy lights blinking.
Try the easy stuff first man. Hot date, eh? "gee baby, sorry it's so dark, but I know what we can do with no lights"
