Fuel filter light - Ford Powerstroke Diesel Forum
Old 06-18-2012, 09:37 PM
Fuel filter light
Hey guys so my fuel filter light was flickering so I figured it may be time for a change. So I replaced my fuel filter and now the light is still coming on. Any ideas?
Old 06-19-2012, 01:40 PM
De-rail in 3... 2... 1...
Couple of things. Fuel pump going out, vacuum switch on bowl, and fpr screen. Does it happen with both tanks?
Old 06-19-2012, 03:52 PM
If this happened when your fuel level was relatively low, your suction screen is probably degraded and in pieces inthe bottom of your tank. That is if your fuel pressure and pump is ok. That its what happened to mine, it sucked up trash and clogged the fuel lines. You can check your tank selector switch also.
Sent from my SCH-I500
