Oil leak - Ford Powerstroke Diesel Forum
Old 06-05-2012, 01:00 PM
Oil leak
Is there a seal or a gasket or a line on the turbo that would cause the truck to lose all oil in a matter of 10 miles?
Sent from my PG86100 using AutoGuide.Com Free App
Old 06-05-2012, 01:07 PM
Ok the whole top of the motor is covered in oil like pooled up in oil.
Old 06-05-2012, 02:12 PM
De-rail in 3... 2... 1...
Turbo only has two small o-rings and a 1" engine oil operated butterfly valve (EBPV). Find the butterfly valve post turbine housing underside, follow the actuator rod back to the turbo pedestal. That's where the leak is from if its the Turbo.
Otherwise,
High Pressure Oil Pump (HPOP) lines. 2000psi of spitting fire.
Old 06-05-2012, 02:14 PM
But with the truck running I still can't seem to find a leak
Old 06-05-2012, 02:20 PM
^^ see edit
Old 06-05-2012, 02:24 PM
Ahh gitchya. Thanks
Old 06-05-2012, 05:42 PM
Check the HP oil lines at the HPOP to hose joints and the HPOP hose to head joints. Also check the unused ports on the heads that correspond to the other cylinders (where the HPOP hoses could alternatively be connected). I had a hose-to-pump o-ring blow out and lost 6 quarts in 5 miles. Cheers!
