97 7.3 Electrical problem!!
alright so i got a weird electrical issue going on, currently i have no blinkers, hazards, brake lights and wipers. first thing i did was check all fuses and relays and every one was good, then i thought it might be the multi function switch so i replaced it twice actually and still no go. anybody got any ideas please help me out. also could use a wiring diagram for the truck if any one has one. thanks..
Curious, all the functions described are in the high side of the rear bulbs. Does the low side of the bulbs work if you pull out the headlight switch? Do the front turn signals work high and low? Sorry, giving you a wiring diagram would be against the rules of the forum as they are protected works. Grab a Chiltons (or the like) for a wiring diagram as well as plenty of other useful info NOT including our engines.
