HARD TO START ACTS LIKE ITS MISSING - Ford Powerstroke Diesel Forum
Old 05-14-2012, 05:35 AM
I own a 95 7.3 pwerstroke that is hard to start and acts like its missing going down the road. I replaced the glow plugs over the weekend along with the cps and the problem may have gotten worse. no check engine light. wts lights up everytime. please advise. thanks
Old 05-14-2012, 05:58 AM
Uvch's. how did they look?
I made my Samsung SGH-I997 send this.
Old 05-14-2012, 07:14 AM
I replaced one of them because when taking it off had busted the clamp, upon further inspection the plug had actually melted a little on the outside 2 wires in the actual plug in. i saw after you suggested it how to test them by unpluggin to see if there is a difference in the motor or not. Is that how you would suggest testing it? thank you for the response.
Old 05-14-2012, 09:33 AM
You can. If all the wires are bad then it'll run the same, but if only one or two are bad, it might run worse.
If the pins are burnt on the outside valve cover side of the harness, I'd replace the pigtail.
RiffRaff, Strictly Diesel, and other places sell that pigtail.
Old 05-14-2012, 09:39 AM
Went out and checked the connections by pulling out the pigtail from the vcg and all acted the same. pulled it out and engine started running rough plug back in back to rough idle. wondering if the CPS I installed may be faulty.
Old 05-14-2012, 09:41 AM
the pigtail that had been burnt was replaced when glow plugs were done. ran buzz test with all injectors sounding off. gave error code p1271 thru p1278 please advise. thanks
