HELP, HELP ! ! - Ford Powerstroke Diesel Forum
post #1 of 7 Old 05-01-2012, 10:15 AM Thread Starter
HELP, HELP ! !
Truck started an shut off ! from then i wasn't able to start again. strong crank ,blowing white smoke! change glow plugs, were do i go from here!?!?!?!?!
islandpower is offline
post #2 of 7 Old 05-01-2012, 10:31 AM
TANPOWERSMOKER's Avatar
befor it shut off how was it running?
when it shut off did it die like you turned the key of or did it stumble and slowly die?
-Brenden-
Theres Nothing Like A Good Cigar
95' F-250 7.3 EXTRACAB 4x4 LONGBED ZF5 238k
M.B.R.P down pipe,4" pipe to 5" turnouts, 6637 INTAKE, FPR SHIM, FP gauge, P.H.P. CHIP, Dana 60 swap, ccv mod, Issapro A-Piller Gauges, Aero force obd2 gauge, Rear 32gal bronco tank, 35" coopers(with no lift
), steel flatbed, home made 7ft track bars,Zf5 swap and valair cluch!!!
(I love Slaming beers...Oh, i mean gears)
SOON TO COME: Rosewood stage 1.5
TANPOWERSMOKER is offline
post #3 of 7 Old 05-01-2012, 10:36 AM Thread Starter
When it shut of it just died like i turn the key. it was running rough not smooth at all
post #4 of 7 Old 05-01-2012, 10:37 AM Thread Starter
Also am looking for a machanic that would come out to me . Am in Ft. lauderdill Florida
post #5 of 7 Old 05-01-2012, 09:14 PM
444 ci's Avatar
could be your cam positiom sensor. when you crank it does your tach move?
444 ci is offline
post #6 of 7 Old 05-01-2012, 10:19 PM
95Strokeee's Avatar
This happened to me! I replaced my glow plugs, I found out the cam sensor was off a '99 F250 (from the knucklehead I bought the truck from) so I replaced that, it started right up. After that I got some Diesel Kleen and a full tank of fuel and it's been running right ever since.
95Strokeee is offline
post #7 of 7 Old 05-02-2012, 02:39 AM Thread Starter
The battery and oil moves . Should there be another one to look for ? plus i changed it about an year or so ago ! could injectors be the problem also?
