how much for gauges? - Ford Powerstroke Diesel Forum
post #1 of 13 Old 04-19-2012, 05:41 PM Thread Starter
19 STROKER 95's Avatar
I want to have guages installed was wondering what a decent price would be.
19 STROKER 95 is offline
post #2 of 13 Old 04-20-2012, 06:16 AM
PSD_rookie's Avatar
Depends on what all you want for gauges and who you want them by, best price is gonna be glowshift, I got all mine for just over $200, then got my 3 gauge pod for like $20 on ebay. Give me a minute and I'll get you a pic of them.
TOTALED - 95 F250 XLT ECLB 4x4
4" turbo back, DIY tymar, Boost/EGT/Trans temp Gauges, 35/12.5 tires, ZF-5 swap with solid driveshaft, Oh yea, and P-pumped 12 valve swap
97 F350 CCLB 4x4
PSD_rookie is offline
post #3 of 13 Old 04-20-2012, 06:26 AM
PSD_rookie's Avatar
Went and snapped you a couple photos, mine are black 7 color gauges, I wouldn't recommend the tinted 7 color cause if you get some sun on them, you can't read it well because the tint. and please disregard the cardboard box on the windshield, it was bright out and I've got 20% tint, so you couldn't see the dang gauges without it.
gauges off:
Engine at idle:
They're pretty easy to install, if you need help there are several writeups on here for that. Hardest part I had was running my wirse up to the A-pillar, mainly cause I've got 5 12ga wires going to my lights up to. Hope this helps
97 F350 CCLB 4x4
post #4 of 13 Old 04-20-2012, 06:36 PM
Running several gauges would be some work but doable. Edge cts can show most of the vital for $400. Its literally plug and play. No brain or labor involved plus trouble code reader. If you want egt is like another $150 I think. And backup cam is about $50 from Amazon.
PioneerODR is offline
post #5 of 13 Old 04-20-2012, 07:03 PM
jesilvas's Avatar
Quoted: 2 Post(s)
An Edge will only show what sensors the truck has.
Soooo . . . no fuel pressure, trans temp, EGT. Oh. The important ones.
And running several gauges really isn't bad. I did it once, did it half way, then went back and did it right and took my time. That's the key. I also ran 4 gauges.
4R100, 2wd
330,000 + miles
jesilvas is offline
post #6 of 13 Old 04-20-2012, 08:22 PM
Quoted: 82 Post(s)
Feedback Score: 4 reviews
Or you could go with better quality and get something like these Ev's that I got from here Isspro Enhanced Visability Gauges for a really good price. You don't mention if you have a manual or auto trans, if you have a manual you don't need the trans temp gauge.
Jack
97 F250 Xlt, built E4od, D60 swap, Baby swamps, tunes by Dp
1.0 housing w/ wwII, 203* t-stat, diy 6637, 4" exhaust
Diy intercooled, 6.0 fan, Diy 140v Idm, Isspro Ev gauges
On board air, 38 Gal rear tank, E-fuel, 6" lift on 35's
322000 miles
1Dieselman is offline
post #7 of 13 Old 04-21-2012, 03:02 PM Thread Starter
YES!!!! That is exactly what I want. First I just want to say thx a bunch for the replies and photos, very much appreciated. Now how hard would it be for your average guy such as myself to install four gauges I was thinking boost,trans temp, egt, and fuel pressure? Any link to a writeup would be appreciated.
post #8 of 13 Old 04-21-2012, 03:05 PM
jesilvas's Avatar
Quoted: 2 Post(s)
It's not hard at all.
Dieselmanor has an install sheet for 7.3s for the three basic gauges.
For wiring, I laid the pod out, and ran a wire for each and every connection on the gauge I'd need, making sure that I left myself enough wire and to make very good connections. That's the biggest thing: good connections.
4R100, 2wd
330,000 + miles
jesilvas is offline
post #9 of 13 Old 04-21-2012, 03:06 PM
Quoted: 82 Post(s)
Not real hard to hook up, the gauges all come with instructions. I you want a 4 gauge pillar pod I got mine here Complete Performance $75 painted and shipped.
Jack
322000 miles
post #10 of 13 Old 04-21-2012, 03:34 PM
Toms01PSD's Avatar
Quoted: 64 Post(s)
I'm on my phone so I can't see where you live but post up in your local chapters forum and see if anyone local can give you a hand. Have a GTG at your place, that's how we did mine. Also, www.kensperformancesolutions.com has a good deal on gauges. 325 shipped and I believe it's $100 more for the 4th gauge and the pillar pod that will hold 4 gauges.
Also, they are ISSPRO EV2 gauges that match the factory gauges and they come with green covers for the bulbs.
Tom
2001 F250 7.3 auto 4x4 Lariat CCSB
6637 intake
4" MBRP exhaust
PHP tunes
Foil delete
EBPV delete
ISSPRO Boost, Pyro, and Trans Gauges
Strictly Diesel Pre-Pump Filter/In-Tank Kit
Strictly Diesel Regulated Return and Fuel Bowl Delete
High Flow Banjo Bolts
Nitto AT's 305/70R16
2009 Pontiac G8 GT
Intake, Exhaust, Tune
Camaro 20's, Camaro SS Brembo's
1997 VDub Passat GLX VR6
Toms01PSD is offline
