97 f350 New! to me lol - Ford Powerstroke Diesel Forum
post #1 of 3 Old 04-14-2012, 02:03 PM Thread Starter
Sold the 08 f350.nothing but problems with it...bought 97 f350 7.3 crew cab long bed..330k mile looks and drives great.is there any problems I need to look for with that many miles? this is my 1st 7.3 ..did smoke white on start up but not much.Also its a 5 speedand i have to shift very slowly like take it from 1st to neutral and ease it into 2nd same with 3rd and 4th or else it grinds. Normal?? ..any tricks of the trades for making it last would be appriciated..Also temp gauge does not work ..Only work done to truck was heads and head gasket and bigger high flow/or pressure oil pump not sure which one it was. Thanks In advance. Also will be towing a 14k lb trailer anything i need to do prior?
Ericr712 is offline
post #2 of 3 Old 04-17-2012, 04:48 PM
1996powerst0ke's Avatar
Look in the valley for oil, check the turbo for shaft play, ALWAYS keep a spare cps with you! Ditch the factory air filter and do the DIY setup, 3 inch down pipe should be on your list to, but since you just bought it I'd change all the fluids and filters at least, also check the intake boots for tears. Ccv mod wouldn't hurt either. I'm sure there's more lol, as for your tranny I'm not sure. If your gonna do anything to the engine get gauges
Tanner
1995 f250 standard cab long bed. ts 6 pos chip, 4 inch exhaust, 6637 intake, gauges, zf5 manual single mass flywheel, lots more to come!
1996powerst0ke is offline
post #3 of 3 Old 04-25-2012, 12:45 PM
the baconator
terryknight's Avatar
Quoted: 146 Post(s)
sounds like your synchros are dieing or dead
94.5 F250 Reg Cab 4x4 5 speed 4.10 276000 plus miles
97 F350 Crew Cab LB 4x4 5 speed 3.55 320000 plus miles (parts truck)
Originally Posted by alberta 7.3 View Post
YouTube: Providing idiots everywhere a podium to share their stupidity
terryknight is offline
