Clutch pedal Sssqueakyy - Ford Powerstroke Diesel Forum
post #1 of 13 Old 09-22-2007, 01:46 PM Thread Starter
BLIZZ's Avatar
Hello new to the Forum , has anyone had a squeaky clutch pedal in a 94 F350 this thing sounds like a haunted house and i have tried everything but taking the pedals out. Is there a plastic bushing in the bracket that suports the pedals ?
94 F350 Dually 4 door, stick, Raven Black , stock
BLIZZ is offline
post #2 of 13 Old 09-22-2007, 02:10 PM
did u see if it was the spring
Early 99 F350-Sold
01 Excursion-Sold
98.5 Cummins-Sold
02 F250- Stock
My Hero
Goose is offline
post #3 of 13 Old 09-22-2007, 02:31 PM Thread Starter
BLIZZ's Avatar
It does sound like the spring but i have oil and greased all the contact points even the throw out bearing arm , the only thing i cannot get to is the support bracket the pedals are attached to" i wish it had a grease fitting" .
BLIZZ is offline
post #4 of 13 Old 09-22-2007, 02:39 PM
grease the cable
Early 99 F350-Sold
01 Excursion-Sold
98.5 Cummins-Sold
02 F250- Stock
My Hero
Goose is offline
post #5 of 13 Old 09-22-2007, 04:26 PM Thread Starter
BLIZZ's Avatar
Originally Posted by GoosedF350 View Post
grease the cable
It has a hydraulic clutch " Throw out bearing " , where is this " cable " located at ?
BLIZZ is offline
post #6 of 13 Old 09-23-2007, 12:11 PM
SMKSTAX's Avatar
I wish I could help ya out, my clutch has been creaking for months too. Don't know what to do about it.
RICK
97 F350 CREW CAB 4x4, 7.3 TURBO DIESEL, DIY INTAKE , TW TUNES
GRAND ROCK POWERFLOW STACK KIT W/5" MITRES
3.55 REARS, 3" DOWNPIPE, FPR SHIMMED WITH GAUGE
SMKSTAX is offline
post #7 of 13 Old 09-23-2007, 12:16 PM
BIG TRUCK, SMALL DRIVER
pipelayerjdh's Avatar
They have plastic bushings on the cross over rod that the clutch pedal is connected to. It runs over to the clutch mastercylinder linkage. Another small bushing is located where the master cylinder rod connects to the clutch pedal linkage. The spring pivot should also have a little grease on it. These trucks don't have a clutch cable.
Derrick
'97 F-350 "FORDOR" 4X4 (Dually Conversion, Shackle Reversal, Technicooler , Auto Meter Gauges, 4" DIY Dual Exhaust w/ '08 tips,
, Wicked Wheel 2, 360 thrust bearing, Homemade E-fuel conversion, Wildman Chip,
) 230K and counting...
pipelayerjdh is offline
post #8 of 13 Old 09-23-2007, 12:21 PM
SMKSTAX's Avatar
Derrick are they hydraulic??
RICK
SMKSTAX is offline
post #9 of 13 Old 09-23-2007, 12:26 PM
They are completely hydraulic. The clutch pedal pushes a rod that operates the clutch master cylinder. It forces break fluid through a hose to the slave cylinder, that operates the clutch fork. I really like the setup, but they do have a few weak points. The bushings are notorious for wearing, and when replacing the master cylinder or slave cylinder, it is difficult to bleed the air out of the system.
Derrick
post #10 of 13 Old 09-23-2007, 12:27 PM
SMKSTAX's Avatar
No adjustments then huh?
RICK
SMKSTAX is offline
