SES light
Hey guys was wondering where exactly the ses light on these trucks are. Mine hasnt worked since I got it. Trying to figure out if it's a bulb or? Thanks
Right side of the cluster. And it says "Check Engine", rather than "Service Engine Soon". Look again; the bulb test is crazy short, like 1/10 second. Keep your eye peeled on that side of the cluster as you turn the key to RUN. Blink, and you'll miss it......
Thanks. Mine is definitely not working. A picture would be great so I can try to replace the bulb.
It's between the seat belt light and the ABS light, in that rightmost column of lights, to the right of the tach. Well I couldn't get a still pic, because it flashes SO fast. I got to play with the slow-mo movie feature on my camera and got a short video.
Did you see it flash? That's actually 1/4 speed; that gives you and idea how short it flashes. I was trying to figure out what sensor to unplug, to force the light on, but.... |
Thank you for the video. Mine is definitely not working and neither is the seatbelt light so I'll have to dig around a bit. Might be a wiring issue going on. Appreciate the help, let you know what I find when I get a chance to work on it in between the 60 swap and all my other projects.
