Rear Fuel Tank Lines Remove - Ford Powerstroke Diesel Forum
Old 03-03-2012, 04:43 PM
I have a leak in my rear fuel tank on my 95 F-250 PSD. I have the tank lowered enough to get to the fuel lines for disconnecting. I am trying to get the fuel lines apart. I got the clips off so now what is the trick to disconnect? Is there a special tool that I should get? Thanks.
Old 03-03-2012, 04:52 PM
Powerstroke Techie
You need a tool such as this:
Or this:
Old 03-03-2012, 05:28 PM
Rear Fuel Tank Lines Remove:
I guess these would be availaable at NAPA or similar. Thanks.
Old 03-03-2012, 06:46 PM
Mine is a 2003 and all that I had to due was push on the blue or white collar that was shown and pull apart. Most of h time if it is before the pump you do not need a tool to discount. Usually only on the high pressure side.
Old 03-03-2012, 07:19 PM
Yours would be a bit different due to the electric fuel on an 03.
Old 03-03-2012, 07:34 PM
Powerstroke Techie
Yeah they should be available at any local parts store.
Old 03-03-2012, 07:48 PM
Yep, my local NAPA store had it. I will get this tank out tonite. Now I have to look to see what a new tank cost or repair mine. I have a spot that rusted out.
Old 03-03-2012, 08:05 PM
Powerstroke Techie
A new tank should be cheaper than trying to repair your old one. Don't forget to order straps with it.
