Trailer Electrical Problems need help - Ford Powerstroke Diesel Forum
post #1 of 5 Old 03-01-2012, 09:56 AM Thread Starter
1995 F-250 Powerstroke, I dont have power at the back of the truck for running lights on trailer. Truck running lights work fine, I do not have power at the brown W/white wire. I tested connectors above the bumper where the trailer pigtail plugs into factory harness and there is no power there either. I do not have a wire diagram of the underhood relays and which one controls the trailer lights. I have tested all fuses and they are all good with continuity across them.
flatland freak is offline
post #2 of 5 Old 03-01-2012, 11:41 AM
Patrick Feeley's Avatar
Quoted: 15 Post(s)
IIRC I think the trailer relay is #3. If I get a chance, I will take a look at my EVTM tonight. Cheers!
Patrick Feeley is offline
post #3 of 5 Old 03-01-2012, 02:41 PM Thread Starter
I would greatly appreciate it.
post #4 of 5 Old 03-01-2012, 05:52 PM
Quoted: 15 Post(s)
Power for the Trailer Marker Lamps comes from Underhood Fuse 4, through Underhood Relay 4 (second closest to the engine ... the closest relay spot, #5, to the engine is not used). The relay is switched by power from the main light switch (when the light switch is in headlight or park light mode). The Brown/White trace wire comes right off the relay and goes through a couple of connectors in the engine compartment. Cheers!
post #5 of 5 Old 03-02-2012, 11:35 AM Thread Starter
Thank you, I will have to track it down. I can hear the #4 relay click when I turn the light switch on so i will have to start there and see where the break is. Thanks for the info I appreciate it.
