Intake boots - Ford Powerstroke Diesel Forum
Old 02-20-2012, 01:59 PM
Intake boots
I was replacing the seals on my CCV today and while taking off the intake from the turbo, noticed the orange boot connecting directly to the turbo is torn where the clamp sits. Does anyone know where I can find a new boot? May as well do the two boots on the Y-pipe too while I'm at it if they're easily available. Thanks yall.
Old 02-20-2012, 07:46 PM
You have three options:
Aftermarket replacement from IntakeHoses.com or RiffRaff Diesel (that's two) or the factory upgrade kit (Ford F7TZ-9C681-AA). The factory kit has a new, much heavier black hose, and all the brackets, adapters, hoses, and hardware. The hose routing is slightly different, hence the need for all the other stuff. It usually runs about $86 or so from someplace like Tousley Ford Parts. Cheers!
Old 02-21-2012, 07:22 AM
Thank you sir! I went ahead and ordered a replacement online. Thanks again
Old 02-21-2012, 11:30 AM
I just ordered one from intakehoses and I couldn't get it to fit right at all. I was very upset that I spent almost $60 on the intake hoses one just to have it not fit. It is like the wall is too thick on it and it hit my valve cover. I am not trying to bash them or anything, but it simply doesn't fit good at all. I ordered the Ford replacement from Tousley Friday.
Old 02-21-2012, 11:49 AM
Which one did you order if you don't mind my asking? Thanks.
Old 02-21-2012, 11:58 AM
I ordered this one:Silicone 45 Degree Reducing Elbow 3-3/8" to 3" 1820102C2 Kit with Clamps: Intake Hoses, IntakeTubing, and Intake Clamps
I read good things about them on other forums, so I ordered it, but I am not happy with it, I guess I will throw it up on the shelf.
Old 02-21-2012, 04:03 PM
I like the factory kit myself (used on both trucks). Cheers!
Old 02-21-2012, 07:25 PM
I just got mine today, didn't even know it showed up. I have to thank you for turning me on to Tousley Ford. I read it on another forum somewhere, parts shipped this morning and had it this afternoon!
Old 06-25-2012, 06:30 AM
Older thread I know but I also ordered the intakehoses one and it doesn't fit at all. Crossthreaded where the intake bolts to a bracket on the valve cover just so I could get it to sit still so I could operate the truck. Will be ordering the Ford one and will probably have to tap the threads on the bracket now.
Old 06-25-2012, 11:49 AM
If you get the factory "kit", it will come with a new breather adapter and bracket for a correct fit. Cheers!
