Truck won't start - Ford Powerstroke Diesel Forum
Old 02-12-2012, 01:48 PM
Send a message via Yahoo to uhdizbucky
Truck won't start
I have a 1995 ford f350 and the fuel filter light came on . The truck started to lose power then just died and now won't start. I already changed fuel filter and fuel pump .... Help !
Old 02-12-2012, 02:28 PM
Fuel filter light? Water in fuel light maybe?
Will it crank fine? Does the WTS light come on?
Old 02-12-2012, 02:41 PM
Yea it cranks fine. The wts light comes on and yea it's the fuel filter light that stays on when the truck died not the water in fuel light
Old 02-12-2012, 02:44 PM
I've never seen the fuel filter light. Must be an OBS thing.
When you changed the fuel filter, did you get the air out of the system? Maybe that's all it is.
Old 02-12-2012, 02:51 PM
I believe so. It ran fine after I changed the filter . But how do I get the air out if it has any?
Old 02-12-2012, 03:05 PM
So what exactly did you do, cause I have no idea.
You changed pump and filter, started it, it ran, then died?
Old 02-12-2012, 03:12 PM
I changed the fuel pumped changed the fuel bowl with the filter also.and the truck ran fine for about a month. Then the fuel filter light would come on every now and then and the truck would lose power and then turn off . It's like if there is restriction in the fuel.
Old 02-12-2012, 04:41 PM
Oh ok. I gotcha now.
I'd check the FPR screen. It might be clogged up. There's a write up on here how to do that.
Old 02-12-2012, 04:49 PM
Yea il have to try that . I was thinking the fuel tank selector valve can be bad also on it .heard some people had the same problem
Old 02-14-2012, 08:24 AM
the light came on then truck died? Maybe you're getting a lot of crud coming up from the tank? If you have air in the lines you'll just have to crank it out. Do you refill the bowl when you out a new filter in?
