97 F250 brake issue
Last week I noticed an large and immediate decrease in the stopping power in my truck. There were no obvious leaks in the system when I went over it. The red brake light would come on somtimes, especially when manuvering in a parking lot when i'm on and off the pedal alot. Seems that there is also now power in them when I first start the truck.
I took it to the shop where they said it was a bad master cylinder resivour. There was only a marginal improvement in performance and the light still comes on and they claim they can't find the problem. RABS gone bad? |
Here's a bump for ya.
Have you checked the vacuum system and brake booster?
Have you noticed any vacuum problems with the ac or heater? If so you could have a leak or pump problem. Are the brakes pulling to either side when you try to stop? Jim |
The ac and heat are fine and it doesn't pull in any direction
Check your vacuum pump might be getting weak. Should have around 27lbs at idle.
i gotta 97 an my breaks arent that good an they pull
If they are pulling you probably need to check the pads and rotors, and make sure you don't have a sticking pistons in the calipers. Could just be time for a brake job, depending on there condition. This is also a good time to repack the front wheel bearings.
Jim |
The pump is pulling vacuum, though not sure how much, easy to pull finger off. Its pulsating and there is a squeeky howl coming out of the vac tube. This normal?
Hope this helps |
I plan on picking one up soon as most of my tools are at home. I hate not being able to work on things much myself in college.
