Truck starts, then dies. Then starts just fine - Ford Powerstroke Diesel Forum
Old 01-31-2012, 07:57 PM
My dad has a '95 Powerstroke that's knocking on the 300,000 mile door. Lately when he goes to start it, it'll start and run for 5 to 10 seconds and die. Wait a little bit, crank it again and she'll start and stay running. Any ideas on where I should start looking?
Old 02-01-2012, 06:12 PM
Me im having trouble with mine,its dieing on me rite after i start it,i changed the fuel filter and thats when it started to die on me,maybe something to do with the fuel filter or cps,im not for sure though i need to figure mine out to,could be the fuel pump,so many things but not for sure what.
Old 02-01-2012, 06:18 PM
the baconator
is it cold when it dies? or does it not matter?
Old 02-02-2012, 05:44 PM
Only after it's been sitting for a couple days. Once it starts, it'll start back up without a problem.
Old 02-02-2012, 06:07 PM
the baconator
just trying to get this right. the truck has been sitting not plugged in,you start the truck it runs for 10 secs and then it dies. you start it right back up and it runs fine all day. until you let it sit hour a couple days? sounds like it has a problem building fuel or oil pressure. do you have any numbers like fuel pressure, oil pressure, icp?
Old 02-02-2012, 06:25 PM
Yeah, I think that kinda sums it up. Unfortunately, the only gauge he has is a pyrometer. Would it do any good to plug my Edge Insight into it?
Old 02-03-2012, 04:03 AM
the baconator
i have no idea, i know nothing about edge products. you can get icp with a high quality scan tool. fuel pressure off the schrader valve or the driver's side of the fuel bowl and high pressure oil pressure off the rails.
Old 02-03-2012, 07:23 AM
Does it read real-time PCM data?
Old 02-03-2012, 11:51 AM
Yes, it does. On my 6.0, it read at least 15 or more different things, trans temp, boost, EOT, ECT, ICP voltage, speed, engine load, etc. I just didn't know what it would be able to read from a 7.3
Old 02-03-2012, 01:30 PM
the baconator
you can always try it. i don't think that there are that many parameters to read. i thik the OBS has 8
