help with codes - Ford Powerstroke Diesel Forum
Old 09-10-2007, 04:14 PM
help with codes
my 95 died on me a few weeks ago and won't start.During cranking,it huffs a bit from intake(a soft popping).Fuel in cannister but no pressure to rails.Could it be cps?My tach does bounce when cranking.Fuses are good and batteries crank over good.i don't have much pressure at bleeder valve on side.i pulled up three codes......P0562(possibly an old code from running down battery), P1661 and P0603.Anybody have any ideas?I hope it's the cps and not the pcm(expensive i think)
Old 09-10-2007, 04:17 PM
BIG TRUCK, SMALL DRIVER
Put a fuel pressure gauge on the schrader valve. You should have a minimum of 40 psi. It could be the fuel pump going out.
Old 09-10-2007, 04:18 PM
my pcm went out new there around 800 at ford but i got a used one and Dallas is putting it in
Old 09-10-2007, 04:29 PM
duct tape & zip ties
P0603, is pcm error, P1661 is Output CKT circuit low, P0562 system low voltage. I recommend you clear the codes and then check your batteries.
Old 09-10-2007, 04:53 PM
If it is your pcm, and you have to get a new one go to DP Tuner. DP-Tuner
Old 09-11-2007, 06:09 PM
Electrical Ogre
p0603 can be set by a dead/disconnected battery, or also as a side effect of using a download tuner.
