Turbo Removal 1997 f350 Powerstoke 7.3 - Ford Powerstroke Diesel Forum
Old 01-14-2012, 06:28 AM
Im in the process of rebuilding my turbo but i have a problem one of the bolts is stripped and i cant get it out if anyone can help it would be much appreciated.
Old 01-14-2012, 06:34 AM
lots of PB blaster and a stripped bolt removal tool
Old 01-14-2012, 06:56 AM
my friend tried an easy off socket we didn't have any luck its in a real tight spot i asked him about pb blaster said it wouldn't make a difference what kind of tool whould you suggest.
Old 01-14-2012, 07:06 AM
Why would it not make difference? If it's seized in that good, it'll help.
Sears: Online department store featuring appliances, tools, fitness equipment and more
This is what I have used.
Old 01-14-2012, 08:02 AM
ok man ill give it a try with that.
Old 01-14-2012, 08:25 AM
Spectator
Wouldn't make a difference? I beg to differ. That's what helped me get mine off. I've removed mine three times and rebuilt it as well.
Old 01-14-2012, 08:46 AM
the baconator
heat is your friend and so is pb blaster or similar.
Old 01-14-2012, 09:14 AM
is it safe to use heat since its on the engine
Old 01-14-2012, 09:17 AM
the baconator
yes, just don't heat anything that will burn ie wiring
Old 01-14-2012, 09:24 AM
Ive had really good luck with these also
Tags
turbo 7.3 powerstoke
