Wipers only work with Headlights on Highbeam - Ford Powerstroke Diesel Forum
post #1 of 4 Old 06-26-2006, 03:18 PM Thread Starter
KW7DSP's Avatar
Cool Wipers only work with Headlights on Highbeam
All functions of the wipers are normal except they only work when the high/low beam selector is in high beam position. Lights can be on or off, but selector must be in high beam position for the wipers to function. Ideas anyone?
KW7DSP is offline
post #2 of 4 Old 06-26-2006, 05:31 PM
Sounds like a multifuction switch going bad. that is the name for that particualr unit that controlls wipers, blinkers, and high/low......i just looked at the wiring diagram and i dont see any corrolation between the two that should make that happen except the switch........but i would have it tested before replacing it.......Marc
mschn99 is offline
post #3 of 4 Old 03-30-2007, 01:04 AM
matt morton's Avatar
mark is right.i had one at work yesterday but the wipers would work only with the door closed and the left blinker on.changed multifunction switch and fixed all.
96 f350 crew cab ex cab 8ft bed duelly.3"dp,4"ex gutted cat,no muff.shimmed fpr.17*hpop,rosewood diy injectors.6 pos chip 6L intercooler. i think im hooked
matt morton is offline
post #4 of 4 Old 03-30-2007, 12:55 PM
duct tape & zip ties
bigcountrysg's Avatar
hey i got that switch i'll hook you up with it if you want pm me. the switch is brand bew in the box from ford dealership.
Your Actions Today, Decide Your Future Tomorrow
2005 6.0 Crew Cab Long Box Lariat, current truck
2004 6.0 destroyed by contaminated fuel
2002 7.3L burnt
bigcountrysg is offline
