serpentine belt 95 PS - Ford Powerstroke Diesel Forum
post #1 of 12 Old 06-23-2006, 07:09 PM Thread Starter
bigmacattack's Avatar
does anybody out there know how to loosen the belt to get the alternator off is there a idler arm that can be moved or loosened
bigmacattack is offline
post #2 of 12 Old 06-23-2006, 07:16 PM
On the left (passsanger) side of hte motor there is a tensioner. it will have a square drive half inch hole in it that you can put a half inch wratchet in to loosen the belt up. the tensioner will probably have two individual pulleys on it......Marc
mschn99 is offline
post #3 of 12 Old 06-23-2006, 07:27 PM Thread Starter
Thanks Marc for replying to my thread so quickly I'll go out and see if I can see what you are talking about. Theres a couple a deals that look like tensioners but I played with them and nothing one of them has a torx bolt on it I turned it but It didnt loosen the belt. Mike
post #4 of 12 Old 06-23-2006, 07:38 PM
look for one that has two pulleys connected by a piece of aluminum. on that piece of aluminum there is a square hole for your half inch wratchet......
i think its the only set of idlers on the passanger side of the motor......
mschn99 is offline
post #5 of 12 Old 06-23-2006, 07:46 PM Thread Starter
The only thing on the passenger side of the motor that could be a tensioner has a #50 torx bolt holding the tensioner to the motor and a 15mm bolt on the tensioner pulley.
post #6 of 12 Old 06-23-2006, 07:47 PM
that is the right area, is there a square thing on the one that has the "arm"....if not, use a 15mm socket on the bolt for the pulley....
mschn99 is offline
post #7 of 12 Old 06-23-2006, 07:55 PM Thread Starter
Thank you Marc, I tried cranking on the 15mm pulley bolt, but it didn't seem like it wanted to move. Should I loosen up the torx bolt on the tensioner and then crank on the 15mm pulley bolt. I don't see anything that could accept a 1/2 " drive.
post #8 of 12 Old 06-23-2006, 07:57 PM
loosening the torx wont help........if there is no half inch drive slot, then just pry harder on the 15.....there is quite a bit of spring tension so you may not have been prying hard enough......i use a large breaker bar when i loosen tensioners.....
mschn99 is offline
post #9 of 12 Old 06-24-2006, 05:00 AM
Brian's Avatar
alt. replacement guidelines!hope this helps. there is a nice write up, just follow the link. the link is for an excursion, but same principal
brian
brian
05 f350 crew, longbed, 4x4, 68k, lariat
Brian is offline
post #10 of 12 Old 06-24-2006, 05:11 AM Thread Starter
Thanks for the link Brian I'll check it out
