No Start - Ford Powerstroke Diesel Forum
Old 09-06-2007, 08:47 AM
No Start
I purchased a 96 service truck not running . It wont start . new batts spinns fast . 3000 lbs hpress , 50 lbs fuel press , all fueses checked , changed CPS , checked some codes P1219 P1280 0472 0603 0344 . I need some ideas
Old 09-06-2007, 08:49 AM
ADMIN AND TECH
looks like to me it either doesnt have enoguh oil pressure , that 1280 code could be the icp sensor bad , p0344 cam sensor code , youve already replaced , start by clearing codes , crank the truck over and see what comes back up, make sure the oil is full and in good shape , if i just bought it i would change it anyway
Old 09-06-2007, 12:31 PM
1219 Is likely a short to ground between the PCM & the IDM..Maybe unhook both & make sure the terminals are free of corrosion ,& look for anywhere a wire could be rubbing on anything...Wiggle test also , while cranking ....
Old 09-06-2007, 12:37 PM
BIG TRUCK, SMALL DRIVER
Welcome to the ORG.!
Good luck with your truck! These guys are great help.
