Oil Leak in 95' PS 7.3L - Ford Powerstroke Diesel Forum
Old 09-03-2007, 10:34 AM
I have a 95' Powerstroke 7.3L that seems to be leaking oil on the passengers side. It appears to be running down the bellhousing and onto the starter. I can't seem to find where the oil is coming from exactly. Any suggestions would be greatly appreciated.
Thanks,
Shane
Last edited by shane95fordps; 09-03-2007 at 11:38 AM. Reason: Add more information...
Old 09-03-2007, 01:01 PM
sometimes if your turbo is leaking it will fill the area underneath the turbo and then run out the back of the motor
Old 09-03-2007, 01:17 PM
it sounds like a valve cover gasket. check all the bolts in the valve cover and try brake cleaning the motor on that side and crank it up to see if it still does it.
