97 psd loss of power when in passing gear - Ford Powerstroke Diesel Forum
post #1 of 12 Old 08-25-2007, 01:10 PM Thread Starter
97_powerstroke77's Avatar
Exclamation 97 psd loss of power when in passing gear
hey all. 1997 psd 4x4 straight 4 inch pipe all stock. my truck lost its normal power when passing someone, at WOT it feels like it is starving for fuel. when I sit in park and rev it up, normally it would let me tach it out, now it starvs at 2600. I looked through all the threads and gcould not find one that really pin pointed the problem. I think it could be fuel pump?? Any help would be awesome! Thanks
1997 4 door 4x4 7.3 powerstroke auto cat delete, on 33's skins
2010 CrewCab FX4 Lariat
Edge Evo CTS Race
DPF & CAT delete 4" pipe from Turbo back
97_powerstroke77 is offline
post #2 of 12 Old 08-25-2007, 09:38 PM
Mavsps's Avatar
change your fuel filter and clean the fpr screen if you havnt yet. That could help. Good luck!
05 powerjoke extended cab.
Sct tuned by innovative
Open downpipe
Traction Bars and Suncoast on the way!
96 powerstroke extended cab 7.3
4x4 393000 miles
2005 duramax lly edge/predator stack
14.3 1/4 mile 2.3 60ft roasting tires
limping the trans at 1000ft
Mavsps is offline
post #3 of 12 Old 08-26-2007, 06:47 AM
BIG TRUCK, SMALL DRIVER
pipelayerjdh's Avatar
Also check the air filter.
Derrick
'97 F-350 "FORDOR" 4X4 (Dually Conversion, Shackle Reversal, Technicooler , Auto Meter Gauges, 4" DIY Dual Exhaust w/ '08 tips,
, Wicked Wheel 2, 360 thrust bearing, Homemade E-fuel conversion, Wildman Chip,
) 230K and counting...
pipelayerjdh is offline
post #4 of 12 Old 08-26-2007, 07:44 AM Thread Starter
fuel filter changed 2 days b4 the symptoms started. The screen is clean as well. Still having issues. I bought a fuel pump, just want to make sure thats it b4 I change it out.. Thanks guys
Edge Evo CTS Race
post #5 of 12 Old 08-26-2007, 08:11 AM
SMKSTAX's Avatar
Let us know if that fixes it. Kinda havin the same issues sometimes.
RICK
97 F350 CREW CAB 4x4, 7.3 TURBO DIESEL, DIY INTAKE , TW TUNES
GRAND ROCK POWERFLOW STACK KIT W/5" MITRES
3.55 REARS, 3" DOWNPIPE, FPR SHIMMED WITH GAUGE
SMKSTAX is offline
post #6 of 12 Old 08-27-2007, 07:37 PM
7.3 tech, supporter
fordnut85's Avatar
Could be the issue, I would check oil pressure, the low pressure oil pump might be starving the HPOP resivoir.
Duane
1994.5 F-350, PSD, 5spd, Crew cab, 2wd, DRW
10k mod
Idle control mod
homeade exhaust brake
Tymar intake
fordnut85 is offline
post #7 of 12 Old 08-28-2007, 12:46 AM
I'm troubleshooting the same problem. So far, I received the following suggestions:
fuel filter (done)
air filter (done)
MAP sensor (done)
thermostat - low temps causing EBPV actuation?
turbo
The first three things still haven't fixed my problem. Next step is the thermostat since I'm pretty sure it's stuck open right now anyway.
Ryan
2002 F250 CC SB 4x4 Lariat - currently all stock except bedside toolboxes
1997 F250 CC SB 4x4 XLT
shuck is offline
post #8 of 12 Old 08-28-2007, 12:49 AM
rankroddin250's Avatar
just unplug the ebpv to see if thats your problem... its a 2 wire plugin underneither your turbo inlet...mines been unplugged for almost a year with out any problems.
A well regulated Militia, being necessary to the security of a free State, the right of the people to keep and bear Arms, shall not be infringed.
The People of a free country should not be scared of their government, the government should be scared of their people.
rankroddin250 is offline
post #9 of 12 Old 08-28-2007, 11:35 AM
I unplugged the EBPV - didn't really seem to make much of a difference. Someone else suggested fuel delivery or oil. That would make some sense since I'm not able to get any black smoke from the exhaust no matter how hard I stomp on it.
shuck is offline
post #10 of 12 Old 08-28-2007, 11:41 AM Thread Starter
Everyone, It was the fuel pump.... I replaced it and BAM! Back to the good ol' POWERstroke!
Edge Evo CTS Race
