'97 7.3 PSD No-Start
Hey Guys!
First time poster as well as first time diesel owner. I’m a greenhorn! I’ve read quite a few threads to try to educate myself prior to posting so that I can give you as much detailed information as possible. Here’s my problem…. My truck won't start. Here's what I've done. · Checked HPO reservoir. It was just about empty. Refilled · Did oil change. Only 10 quarts drained out. · Changed fuel filter (bowl was full) filter was black & slimy. · Checked fuel pressure off Schrader valve, built to 53 psi while cranking. · 12.5 V on batteries, although I haven't checked while cranking; will do in AM. · Tach reads 200-300 while cranking; Does this rule out CPS?? · Checked all fuses both under hood & dash. · Swapped relays with #3 (Horn) to verify all working. · Checked HPO reservoir & the level is holding. · 11.5 volts at IPR. · 5.1 volts at ICP. · Disconnected ICP & tried cranking. No start · Borrowed an OBDII code reader from AutoZone; No codes. I've cranked the heck out of this thing for 20 seconds at a time while waiting two minutes in between so as not to fry my starter. There is no smoke from tail pipe. I’m thinking back to the empty HPO reservoir… No Pressure = No Fuel & No Fuel = No Smoke! How can I check the pressure from the HPOP? What kind of gauge & where do you connect it? Is the Schrader valve before the filter? If so, should I check for fuel after the filter? If so, how & where? I don’t know if this is an issue or not but… I think my GPR may be bad. I’ve got a constant 12v on one large post (black & orange wire). I’ve tried to check the other large post (Brown & yellow wires). There’s no voltage here. When I turn the key on the WTS light comes on for barely two seconds and switches off. This is when I should have voltage, right? I can also hear a relay click somewhere under the hood. It has been in the 90-degree range all week so I wouldn’t have thought that I would need glow plugs. However, I thought I read something about a bad GPR affecting the PCM & the PCM disabling injectors. Well, at least I stuck in the driveway and not on the road!! Please help! |
Im not Master Techie, but i do have one question. How was the truck running prior to this no-start issue?
Also for this being your first post, congrats, very very detailed. Im sure someone with more knowledge than me will be along. |
It ran well other than occasionally cutting out while driving down the interstate. I attributed this to a faulty CPS & replaced it yesterday.
welcome to the org. and sounds like youve done your research , good job on detail, you said your hpo reservoir was empty when you first started diag, has it filled up now and is the oil pressure gauge going up when cranking ,let start there , need to verify we have god base engine oil pressure to reservoir
Thanks for the comments on the details.
I pulled the plug on HPOR and put almost a quart in. The level has been holding. The oil pressure gauge on the dash does move up to the middle while cranking. I also pulled the high pressure hose from HPOP going to driver's side head, connected it to a tube & ran it into a clear 1 gallon container. I cranked for 10 seconds and only had about 3-4 ounces of oil. It was definitely not under high pressure! Bad HPOP or sticking IPR? What creates the pressure and how do I isolate it? Thanks! |
the icp sensor , sends signal to pcm as far as how much pressure is in the oil rail, depending on that reading the pcm in turn , regulates how open the ipr regulator needs to open to allow the correct oil pressure to the injectors , you can remove the ipr and inspect it , but more than likely you have a hpop thats not working
Before going into tearing the HPOP out i would first do a pressure check a good article to do that is right here.
This article is for a running truck, but has some great info HPOP |
