oil in turbo inlet - Ford Powerstroke Diesel Forum
Old 08-12-2007, 10:01 AM
oil in turbo inlet
I recently bought my truck, a 96 f250, and was going over it, I am not very experienced in mechanics and even less so concerning diesels, but when I found oil in my turbo inlet tube, most of it old and caked but some fresh. Is this a problem or a normal thing. Also, I never hear my turbo spool up, the truck is completely stock, the only thing i notice is in 2nd gear when it starts to hit 2000 rmps I hear a wooshing, like a lot of air is moving. Any ideas on either question?
Old 08-12-2007, 10:23 AM
Can't help ya but I can bump it back to the top for ya.
to the ORG!!
Old 08-12-2007, 10:34 AM
the oil is normal, thats from the crankcase vent system...
as far as the turbo...u say you dont hear it, but is the power good??
Old 08-12-2007, 10:36 AM
Power is fine, its a little sluggish in 2nd but as close as i can tell it pulls like a stock engine should.
Old 08-12-2007, 11:43 AM
hmmm maybe a boost leak.... check your uppipes for soot
Old 08-13-2007, 12:11 PM
BIG TRUCK, SMALL DRIVER
Most OBS turbos are hard to hear over the engine noise. If you add a high flow intake and filter and exhaust you will be able to hear it. When I was running my stock filter and box, I could only hear the turbo when I got close to 2500 RPM.
