Heres the story i plugged in my trailer the other day and that night i went to take it home. I turned my lights on and no running lights and no dash lights. I checked all fuses interior and under the hood. I moved all of my relays around to check those. I tried another light switch. When i jump the switch at the switch plug the running lights work. I am stumpped and need some help. Thanks for your time.
sounds like you need to try swapping the switch for a new one.
I'd replace the switch and also check your trailer for a short that may be overloading the circuit. I'd put a fuse in the line from the trailer to the truck.
I replaced the switch for the second time. The running lights still will not work unless i bypass the switch and jump a hot to the running lights wires of the wireing harness. People say there may be a short in the ground. Where do i even Start? where do i go from here?
remove the trailer lights and try again if the lights work then you need to look at the trailer if they still don't work try again.
the Trailer hasnt been hooked up since this happened. the trailer harness is a direct connect that goes in behind rear bumper. I have removed that and it still doesnt work.
You may have a bad ground somewhere
I checked the power to the switch and it had none. It was like a fuse was blown but none are. So i ran a direct line from the sylanoid with an inline fuse to the switch and now everything works like it is suppose to. Thanks guys for your help.
