Cylinder Head re-surfacing - Ford Powerstroke Diesel Forum
Old 03-21-2011, 08:56 AM
Question... On a 1995 - 7.3 what if any valve train adjustments would be required after re-surfacing the heads (.007) & machining / re-surfacing the valves & seats.
Thanks,
Deegasman:
Old 03-30-2011, 06:26 PM
Feedback Score: 3 reviews
Use a thicker head gasket there are no adjustments to the rocker arms they're bolt and go. You could chance it and see if the hydro lifters will let you go down a little but if not then you might have a clearance issue. Did the shop tell you to do anything i forgot what the piston to valve clearance is.
Old 03-31-2011, 03:19 AM
Thanks for the reply 350Kid.... I've been trying to locate the factory clearace specfications but havent had any luck. I know they are out there some where. Anybody know what they are???
Thanks,
Deegasman
