i need some help on this one - Ford Powerstroke Diesel Forum
Old 03-11-2011, 08:23 AM
power and throttle issues ,approx 50 psi fuel,i tried the bb mod on the fuel reg and my pressure droped to 20 psi ,the ipc is bad what do i do,any ideas thanks
Old 03-15-2011, 06:52 AM
Full A-Team Member
Well if the pressure dropped something happened with the spring when you put it back in. If you have a bad ICP it can really mess with things
Old 03-15-2011, 05:01 PM
thanks for the help ,you guys are awsome .i have read alot or your threads and learned alot.i found the screen in the regulator was plugged ,although i would like to find a breakdown of the reg on the filter housing. the fuel psi is approx 60 a bb brought it to75 is that too much i removed bb and replaced the ipc runs great and alot more power. let me know thanks again bob ferrell, ps headed to montana ill let you know my milage.
