97 7.3 limping - Ford Powerstroke Diesel Forum
Old 03-08-2011, 05:02 AM
97 7.3 limping
My brother in laws 1997 7.3 died on him last night(sort of). He said that the other day when he drove it that his filter light came on for a few minutes then went off. He planned on servicing it this week end any ways. I found out he hasn't changed it in over a year Anyways, he went to leave last night and he lost power and developed a bad miss(like it lost more than one cylinder). He was able to turn around and get it to coast back into his yard where it wouldn't crank back up. He went on to work in another car and when I got home I went to look at it for him. His fuel filter was solid with black gunk, and rusty water. I drained it ,cleaned it, made sure it was pumping fuel and put the new filter in it. It took a second but it fired up on its own and idled. You can rev it but it has a very bad miss and if you wot it takes a few seconds to build rpm's and even then you can tell its lost most its power. What are his options?? Run a cleaner and hope for the best? Pull all the injecters and have them cleaned and rebuilt? Or ?????
Side note--All the harness looked good and I didn't have a chance to check for codes. Since I found all the crap in the filter I figured that was the issue.
Old 03-08-2011, 08:28 AM
Old 03-08-2011, 08:38 AM
Shaking the Bush Boss
pull the fuel regulator off of the bowl....theres a small screen (filter) that can get stopped up, causing a restrition. Be sure to put a rag under the FPR, so the screen dosent fall into the valley. Thats where I'd start.
Old 03-08-2011, 08:41 AM
Thanks! I am going to work on it Saturday so I will let you all know. Any other suggestions while I am there?
Old 03-08-2011, 08:44 AM
you shouldnt have to pull the fuel lines off. Remove the 3(?) bolts and ease the FPR from the bowl. The screen is about the size of a dime and thin. dont drop it in the valley ... thats where the rag undrneath comes in ... or you'll be pulling the fuel bowl completly out.. Dont ask me how I know!
Old 03-08-2011, 08:56 AM
Ok I won't ask Thanks for the info, I will let you Sat.
Old 03-08-2011, 09:15 AM
Did you have any trouble getting the snap ring off the bottom of the FPR housing with the bowl installed?
Old 03-08-2011, 03:52 PM
I may be missing something..but never came across a snap ring
Old 03-08-2011, 04:03 PM
is that black crud oil by chance???
Old 03-08-2011, 04:07 PM
if its on the filter (screen) it is more than likly O ring material from the injectors, and some trash that made it through....
