No wait to start light. - Ford Powerstroke Diesel Forum
Old 02-20-2011, 12:01 PM
I started my truck up this morning with no problems. When i was backing up the truck the engine died. Tired to start back up and nothing just crank and no wait to start light. Checked all fuses and relays in cab and under hood. They all had power. The relay for the glow plugs has power going it. I am out of ideas and was wondering if there is anything else to check.
Old 02-20-2011, 12:35 PM
Powerstroke Techie
Unplug your fuel heater (red wire on driver's side of fuel bowl about halfway down) replace fuse #22 under hood(20 Amp Maxi) then retest and see if it starts
Old 02-20-2011, 12:54 PM
Thanks I checked the the 22 fuse and its not blown check with test light and has power going across.
Old 02-20-2011, 01:02 PM
Powerstroke Techie
Did you pull it out and look at it? I had a blown fuse the other day that the module was backfeeding enough voltage to light the test light. Check to see if you have power on the red wire for the fuel heater.
Old 02-20-2011, 01:13 PM
Ok I will check tomorrow just got called in to plow.
Old 03-07-2011, 03:13 PM
Well finally got back to working on my truck. I tested the red wire for the filter heater. It does have power their. I had also tried the idm box in my friends truck and it fired right up. So i know it is not the idm. Anyone know what direction to go from here.
Old 03-12-2011, 07:27 AM
I was the ecm. I hooked up my buds edge programmer and it said connection failure check to see if key is in on position and retry. Not sure what could have caused it. Getting one out of junkyard for $195. Thanks for the help.
Old 03-12-2011, 05:59 PM
I am having the same prob I got a reman pcm from oriely for $110 but no change so I tryed it on a freinds and it wasfine still havent found my prob
Old 03-20-2011, 06:30 AM
Did the ecm do the trick??? Mine turned out to be a bad ebc it was shorting to ground and shutting every thing down good luck
Old 03-20-2011, 06:32 AM
sorry ebp (exhaust back pressure)
