Fuel Tank Selector Switch Issues/questions - Ford Powerstroke Diesel Forum
post #1 of 4 Old 02-01-2011, 09:00 AM Thread Starter
Alright, So I ran out of fuel twice in 2 months.
The first time it happened was at home. No big deal, just drove my car instead.
The second time was in the pouring rain, about 5 miles from home with my wife and 1 yr old daughter with me. No fun.
It was after the second time when I realized the cause of the problem. I haven't had a chance to try to fix it yet. I'm just running it as a single tank truck.
My diagnosis so far: I flip the tank selector switch from the front to the rear tank, the gauge shows the actual level of the fuel in the rear tank (slam damn Full btw), but it never actually switches the valve. No matter what the dash says, it's still pulling from the front tank.
I don't feel quite so dumb anymore, but I'd like to be able to burn the fuel out of that rear tank. I'd put money the fuel that was in there when I bought it is red fuel. I topped it off before I knew what was wrong. It would SUCK to get dipped on a tank I can't even use right now.
Where is the selector valve located? I haven't had a diesel bath in a while, so I figure I'm ready to hop in and try to replace this bad boy.
Anybody done it recently? write-ups? tips?
Thanks,
Adam
1997 F350 4x4, 7.3, 5 speed, regular cab, dual rear wheels, PTO winch and some other stuff.
"If you don't have parts left over, you did something WRONG!" - Dad
Amphibious is offline
post #2 of 4 Old 02-02-2011, 10:28 AM
freakyjlh's Avatar
Send a message via Yahoo to freakyjlh
I've got a 96 OBS and it is located on the driver's side frame rail. With dual tanks, it should be located right at the front edge of the forward tank. Seems easy to change from what I can tell.
freakyjlh is offline
post #3 of 4 Old 02-21-2011, 08:11 PM
I am not sure if the diesel is different but I had a gasser once that had a berry difficult to isolate fuel delivery problem. Come to eventually find out there was actually a filter inside the switching valve. In my case it was clogged and I had intermittent total loss of fuel (both tanks).
Anyway, my point is just that there is more going on inside that switching valve than most basic shop manuals display.
I would try to rig something out to temporarily change/swap the supply lines to the valve (front vs rear). That way you should be able to determine if your problem is in the valve or not.
Good luck
normal is offline
post #4 of 4 Old 02-21-2011, 08:13 PM
Ps: with regards to possible red fuel, have you considered syphoning into working tank (so you can burn it up) or just syphon enough to check if red?
normal is offline
Tags
dual tanks , fuel , selector , tank , valve
